Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4500 Discussions
Server Board S3420GP RAM Configuration
MHerf
I have a problem with my S3420GP Board by using M393B5170DZ1-CF8 RAM Modules. After Installing one or two RAM Modules I get 3 beeps, which indicates an incorrect RAM Configuration. By reading the compatibilty list (http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030738.htm Intel® Server Board S3420GP — Memory and Hardware Compatibility) I found the module:
SamsungM393B5170DZ1-CF84 GBRegistered1066 MHzDualK4B1G0446D-HCF8SamsungN/A1.5 Volts
I have also installed the latest BIOS Update of 2014.
Any help?
Michael
AChan85
Do not trust the beeps and the lights. I had the same problem with my S3420GPLX board. It says RAM error by looking up the error code. But I know the RAMs are good.
I reset the BIOS many times. A lot of errors are related to the RAID controller. But now everything works just fine, with the exact same hardware.....
Just have to keep trying....
MHerf
Hi Red Sun,
thx for the hint. I will try again. I will give an information in any case of success or not.
DSilv11
Valued Contributor III
DIMMS installed in the Blue slots?
DIMMS need to be filled starting with the blue slots and then filling the slots working toward the CPU,
