Server Products
4772 Discussions
Server Board s5400sf RAID controler driver - vmware
Hello ppl,
I've been searching for a solution to install vmware on a server with a s5400sf board, but i need to use RAID1
I've searched everywhere and didn't found any driver for vmware, is this true? anyone knows where can it be found.
On intel download site there are Win / linux drivers, but i can't find any vmware....certain there must be an explanation, come on...vmware is very used
Anyone has any experience with this server board s5400sf with RAID1 and vmware?
thanks guys
Edward_Z_Intel
The onboard ESRT2 RAID doesn't support VMware. If you want RAID 1, install a hardware RAID controller. Check http://www.vmware.com/go/hcl www.vmware.com/go/hcl for supported controllers.
Thanks for the quick answer, so there's no way to have RAID 1 (software) with VMware on this board?
It's kinda of hard to believe, don't be mad, but there's drivers for win / linux, and nothing for vmware?
Edward_Z_Intel
I'm afraid the answer is no.
Edward_Z_Intel
VMware is not actually validated on S5400SF. However, if you check the supported OS list on the boards that supports VMware, you'll see a note saying ESRT2 is not support, for example, http://www.intel.com/support/motherboards/server/sb/CS-033209.htm Server Products — Operating System Compatibility
Edward_Z_Intel
You may also want to check http://www.intel.com/support/motherboards/server/s5400SF/sb/CS-028454.htm Intel� Server Board S5400SF — Hardware, Memory, and Operating System Compatibility and see if the RAID controller is compatible with the server board.
