Server Products
4784 Discussions
Server Drawings
JPark551
Is there anywhere that I can access drawings for a server chassis, server board, and compute module?
Thank,
Jordan Parker
Hello jordanpa,
Thank you for contacting Intel® Technical Support.
I understand that you looking to have access to Intel's drawings (blue prints) for server chassis, server board or/and compute modules.
In an effort to better assist you can you please indicate the following:
  • The reason for this request?
  • Any specific product or model to which you need this request?
Your prompt response is highly appreciated.
Jeremiah A.
JPark551
This is for a school engineering project where we are designing a supercomputer. One of the deliverable's is to have a 3D representation of the final design. Our team has determined that your products meet our design criteria. The products that I am looking for include:
Intel Xeon Phi 7250 Processor, Intel Compute Module HNS7200APL, Intel Server Board S7200AP, and Intel® Server Chassis H2216XXLR2.
So far this is all our team has chosen for our design. We will also be working on choosing a heatsink and switches that we will potentially need dimensions/drawings for.
-Jordan Parker
Hello Jordan,
Thank you for your quick response.
Ok, based on this information I will go ahead look for the blue prints or dimensions for the products you mentioned.
I will get back to you as soon as I get the information.
Jeremiah A.
Intel(R) Technical Support.
Hello Jordan,
I hope you are doing well today.
Here is what I found: For the Intel Compute Module HNS7200APL and Intel Server Board S7200AP, you can check the topic 2.5 Mechanical Dimensions and Weight listed https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S7200AP_HNS7200AP_TPS_R1_0.pdf here. For the Intel® Server Chassis H2216XXLR2 you can check the topic: Table 1. Chassis Feature Set listed https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/H35971-001_H2000G_TPS.pdf here.
I hope this information helps. Please let me know if there is something else I can help you, more than glad to assist.
Jeremiah A.
Hi Jordan,
I'm following with you to see if the information information provided was fine or if there something else I can help you with.
Jeremiah A.
Hi Jordan,
I'm following with you to see if the information provided was ok or if there something else I can help you with.
Jeremiah A.
JPark551
Yes, you can tell me if the Xeon phi 7250 processor runs x86 instruction set without recompiling?
Hi Jordan,
I was checking upon your question and the Xeon phi 7250 only supports Instruction Set in 64-bit and Instruction Set Extensions in Intel(R) AVX-512. You can confirm this information at the following links:
https://ark.intel.com/products/94035/Intel-Xeon-Phi-Processor-7250-16GB-1_40-GHz-68-core
https://www.intel.com/content/www/us/en/products/processors/xeon-phi/xeon-phi-processors/7250.html?wapkw=xeon+phi+7250
Topic: Instruction Set.
I hope this information clarify your query.
Jeremiah A.
Hi Jordan,
Jeremiah A.
JPark551
I have already found that information. It doesn't answer my question. Can the Xeon phi chip run using the x86 instruction set without recompiling?
Hi Jordan,
Let me investigate and get back to you with information as soon as possible.
Hi Jordan,
I apologize for the delay with the answer to your query.
Below is the response sent from our engineer to your question: Can the Xeon phi chip run using the x86 instruction set without recompiling?
" I am not sure I understand, is the code been compiled for IA or the x86 instruction set? If yes then they are fine and they will not need to recompile the code. However if they are asking about code that was compiled for something like RISK or SPARK or ARM then yes they will need to recompile. I suspect it is the first scenario, they are good to go, their prior x86 code will work fine."
Please let me know if there is something else I can help you with.
regards,
Jeremiah A.
Hi Jordan,
I'm following up with you to see if the information provided helps. Please let me know if there is something else I can help you with or if I can go ahead and close this case.
Jeremiah A.
JPark551
There is another case that Intel is working on regarding this matter.
