Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Server board S2600CP2 1-5-1-2 beep code
zchen39
I just bought brand new Intel server board S2600CP2, installed with 128 (16*8G DDR4-1600) RAM, 2 X E5-2620 processor, attached all power cable (server board, 2 CPUs), with 1000W PSU, but when I try to first time power on the server, i receive 1-5-1-2 beep code, the system can't start, nothing showing on screen (actually no signal output).
I checked manual, 1-5-1-2 beep code means: VR Watchdog Timer sensor assertion.
Anyone has any idea?
Maybe I should go MicroCenter exchange one but they only has one left.
Daniel_O_Intel
Hello -
This means the BMC did not get a SystemPowerGood signal, in the 500ms timeout period. If disconnecting and reseating the power supply connectors does not solve the issue, make sure the chassis power supply is pinned out correctly and providing sufficient amperage.
References:
http://www.intel.com/support/motherboards/server/s2600cp/sb/CS-033291.htm Intel� Server Board S2600CP Family — Chassis Compatibility
http://www.intel.com/support/motherboards/server/s2600cp/sb/CS-033128.htm Intel� Server Board S2600CP Family — Technical Product Specification
