Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
Server board S2600CW, after Enable in BIOS - Intel (R) Virtualization Tehnology not boot Windows Server 2012 R2 Standard!
DDmit2
Need help!
ttsoj
Does Windows boot if you disable Virtualization Technology?
What is on the picture you send that could help us help?
To answer your question, Windows should boot up just fine if Intel VT is enabled or disabled.
DDmit2
Windows not boot if Intel VT is enabled or disabled.
Windows now generally I ceased to boot, even from a setup disk!
DDmit2
Windows 2008 R2 - is installed from an install disk normally. Problem only with Windows server 2012 R2!
DDmit2
Windows isn't boot if Disable Technology of Virtualization.
On the picture the moment is shown when Windows freezes.
We would like to inform you that enabling/disabling virtualization technology in the BIOS will not prevent the operating system to boot up. Here are our recommendations:
- Proceed to update the firmware on the server board to the latest version available:
https://downloadcenter.intel.com/download/26197/Intel-Server-Board-S2600CW-Firmware-Update-Package-for-Extensible-Firmware-Interface-EFI-?product=88278 Intel® Server Board S2600CW Firmware Update Package for Extensible Firmware Interface (EFI)
- Restore to defaults by going into the BIOS set up menu and pressing F9.
Test the system again and let us know the results.
