Server Products
4778 Discussions
Since the ubuntu update on DEVCLOUD I can't use common commands to get job info
virtualdvid
Innovator
I started a couple jobs yesterday and checking the documentation I couldn't execute simple commands such as qstat -f <JOB ID>. Here some examples:
qstat (works perfectly and shows the current active jobs)
XXXX.v-qsvr-1 <script> <uXXXXX> 05:03:57 R batch
but if I use qpeek to check this jobs, here the outputs:
qpeek -o XXXX.v-qsvr-1 qstat: Unknown Job Id Error XXXX.v-qsvr-1 Job XXXX.v-qsvr-1 is not running!
I can't even delete a current job
qdel XXXX.v-qsvr-1 qdel: nonexistent job id: XXXX.v-qsvr-1
What am I doing wrong? Thanks!
David Molina
I'm sorry if I classified wrong this question I couldn't find an option for DEVCLOUD. 🙂
Emeth_O_Intel
Hi David, Thank you for contacting us about this concern. I would like to refer you to the following Forum, please check the link below: https://forums.intel.com/s/topic/0TO0P00000018NNWAY/ Feel free to ask on that site any question and they will be more than happy to assist you about the DEVCLOUD information. Regards, Emeth O. Intel Customer Support Technician. Under Contract to Intel Corporation.
virtualdvid
Innovator
I will ask in the other forum! May you delete this post. I couldn't do it. Thanks!! 🙂
