I am configuring a SUN Fire 4150 server which i have 4 onboard network adapters namely, 2 x Intel Pro 1000 EB network connection with I/O acceleration and 2 x Intel Pro PT Dual port network connection.
I am teaming either 2 of the adapters using ProSet version 13_1_2 on Windows 2008 64bit platform. I can successfully install ProSet and perform teaming but the connection appear at the network connection property page was disabled after teaming is done. There was no way to enable the connection. I have checked the events log and error was detected. I have tried teaming the adapters with and without network cables going into a hub.
I have read the website and followed all the instructions. I hope you will be able to help me with the problem.
Thank you.
