The flashupdt program hangs on my system when using the -i or -u options:
(I had to use the task manager ti kill it after 60 min of running)
c:\Program Files (x86)\Intel\Flashupdt>
c:\Program Files (x86)\Intel\Flashupdt>flashupdt.exe -u c:\Users\Administrator\Downloads\S5000PSL_BIOS101_BMC66_FRUSDR48\flashupdt.c
fg
One-Boot Flash Update Utility Ver 9.61 Build 2
Copyright (c) Intel Corporation 2005-2007
c:\Program Files (x86)\Intel\Flashupdt>flashupdt.exe -i
Then Nothing - the task manager reports 13% CPU from flashupdt.exe.
How do I fix this?
I posted another discussion regarding running the BIOS101.bat update script from a DOS bootable USB stick with similar results.
It appears that I'm at a dead end on the BIOS upgrade path and yet there is a specific fix losted in the new BIOS release notes that I need.
Please help. I'll try just about anything at this point.
Note that the windows install I used here was solely for the purpose of running flashupdt as I usually use Linux.
-Bruce
Finally got it working by booting from Intel boot CD and pulling BIOS from USB.
This is the only option that works, the other 2 are broken.
It should be made clearer what the options are. It took me a days of screwing around to finally realize that there's a boot CD you can use for this.
-Bruce
