Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Unable to Install Windows Server 2012 in MFS5520VIR
Jump to solution
Hello There,
Today i have tried to install Windows Server 2012 in MFS5520VIR Model Server. But it says HDD is offline. When i see the same in diskpart or in the BIOS it is showing as Online.
Advanced drive options are not getting enabled. Says unable to install windows on GPT partition, change the settings in the BIOS but unable to found.
There is a 6 server all of them are giving me the same error. Also i tried to install Windows Hyper V Server setup but result is same. Please help me on the same.
Accepted Solutions
Highlighted
Community Manager
The answer from forum user JFFulcrum is correct, such Operating System is not supported by the compute module:
http://www.intel.com/support/motherboards/server/MFS5520VI/sb/CS-030301.htm Intel® Modular Server Systems — Tested Hardware and Operating System List (THOL)
Highlighted
Valued Contributor III
I`m afraid that Windows Server 2012 is not supported - http://www.intel.com/support/motherboards/server/MFS5520VI/sb/CS-030301.htm Intel® Modular Server Systems — Tested Hardware and Operating System List (THOL) . No drivers available too
https://downloadcenter.intel.com/product/77890/Intel-Compute-Module-MFS5000VI-Family https://downloadcenter.intel.com/product/77890/Intel-Compute-Module-MFS5000VI-Family
Highlighted
Community Manager
