I have a server with the S2600CW2 board whose BMC web console I can access over HTTP.
When I try to access it over HTTPS, it does not respond however.
What could be the cause of this and what else can I do to troubleshoot/resolve it?
Hi User2124,
You may need to first upload a SSL certificate to BMC. The steps to do that can be found at http://download.intel.com/support/motherboards/server/sb/intel_rmm4_ibwc_userguide_r2_72.pdf page 90 section 7.3.7
However, I will find out if there are any other alternatives and let you know as soon as I get an update.
Franklin S.
Intel® Technical Support
Where can I download a copy of the default Intel certificate?
Hi User2124,
The BMC module should be auto generating a self signed certificate that you could use to start connecting through https. The upload a SSL certificate option is there so that you can get a valid certificate from a certificate authority and load it to BMC which is recommended.
However, https can be enabled from the web console in Configuration > Security Settings. Then check on HTTP/HTTPS and there is also an option to force HTTPS. Please try this and let us know how it goes.
What version of BMC are you currently using?
Franklin S.
Hello User2124,
Where you able to try my suggestion on the settings section of the BMC web console? Please let me know if you have additional questions.
Franklin S.
Hello User2124,
Do you still need assistance with the problem you had connecting to BMC through https? Please let us know if you need further assistance.
Franklin S.
