Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5079 Discussions
Unable to run L1 app from the Github repo
IPS
we are trying to run the L1app from the github repo(https://github.com/intel/FlexRAN.git) which is compiled on skylake/cascadelake servers. We are using icelake cpu on the server and BIOS settings and core pinnings are matched according to the FlexRAN document. We compiled libxran.so, libwls.so and FAPI translator binaries from the ORAN-SC PHY repo. The FAPI_translator is now acting as the bridge between L1 and L2. Whenever we are running L1app in any of the modes, we are getting the below error. Can you help us in compiling the l1app alone without any libwls,libxran and fapi translators.
./l1app: 1: version: not found
./l1app: 2: oid: not found
size: '304651248': No such file
Cleanup after [PID] 44515
Ragulan_Intel
Hello IPS,
Thank you for reaching out to Intel Community Forum!
Upon checking your inquiry, we advise to open an IPS case for direct assistance. The IPS team will be able to provide additional support regarding the issue.
Instructions for opening an IPS case can be found here:
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
After registration, you will be able to open a case on the Intel® Premier Support (IPS) platform and your request will be handled by one of our engineers as soon as possible.
With this we are notifying you that your request will be archived as there are no pending actions from Intel Customer Support.
Thank You & Best Regards,
Ragulan_Intel
