Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Unable to update RS2BL040 f/w
diablo_692
I have a Windows 7 Pro x64 system running the RS2BL040 RAID controller. Out of the box the RS2BL040 is running f/w version 2.70.03-0862 as shown by RWC2 version 12.08.03.02. I downloaded the latest O/S independent f/w from the RS2BL040 support site. It is f/w package version 12.12.0-124 containing the f/w version 2.130.363-1846. From within RWC2 I browse to the MR48.rom file, select it, and I confirm that I want to replace the existing f/w with the new f/w. The process begins, but then fails with the message "Failed to flash f/w image because flash command sequence is incorrect or previous f/w flash operation was terminated". The message in the RWC2 log file is "Flash downloaded image corrupt". I downloaded the same package again from the support site, unzipped it, and tried the process again with the same result.
Anyone know what the issue might be?
Edward_Z_Intel
Can you try to update it using command line? Extract files under CmdTool2\Windows into the same folder as MR48.rom, and run the following command:
CmdTool2 -adpfwflash -f MR48.rom -aall
diablo_692
Edward, thanks for the response. Pardon my newb question, but where do I type the command you mentioned in your post? Do I type it in a DOS command line window from within Windows 7 or somewhere else? Do I need to download the Command Line Tool for Windows to do what you suggested? Now you know why I tried to use RWC2 to perform the update.
Edward_Z_Intel
In a command prompt window (cmd) within Windows 7.
diablo_692
I ran this with the MR48.rom file and cmdtool264.exe file in the temp directory:
c:\temp> cmdtool264 -adpfwflash -f MR48.rom -aall
and here were the results:
CreateFile failed with error: 5
Exit Code: 0x01
I was going to attach the log file, but couldn't figure out how. I only see editor options to attach pictures, videos, and links; no file attach.
Edward_Z_Intel
I believe you have administrator privilege right? Can you try to start the command prompt window as administrator?
diablo_692
I am the only user of this PC and I have Administrator rights.
Edward_Z_Intel
Could you try to run command prompt as Administrator:
Click the start button. In the search box, type cmd. When cmd.exe pops up, right click on it and select "Run as administrator". Then run the cmdtool2 command.
diablo_692
Ok, I did what you suggested (not sure why running as Administrator was needed as my account info shows I have Administrator rights) and here was the result:
Adaptor 0: Intel (R) RAID Controller RS2BL040
Vendor ID: 0x1000, Device ID: 0x0079
Package version on the controller: 12.7.0-0007
Package version of the image file: 12.12.0-0124
Download Completed.
Flashing image to adapter...
Firmware Failed to Flash flash. Stop!!!
FW error description:
The requested command cannot be completed as the image is corrupted.
Exit Code: 0x13
diablo_692
I don't mind at all, but unfortunately I got the same results:
c:\temp> cmdtool264 -adpfwflash -f 2108_p35.rom -aall
Package version of the image file: 12.12.0-0111
Download Completed.
Exit Code: 0x13
By the way, thanks Edward for all your help in assisting me to figure out this issue. It is puzzling.
diablo_692
With version -0036 which f/w binary should I use, the large 8MB one or the smaller one?
Edward_Z_Intel
The smaller one, mr_m09p1.rom.
diablo_692
It appears that the flash to -0036 completed successfully - thank you. I will update the f/w incrementally until I get to the latest version like the other poster did with the RS2BL080.
Should I do like the readme file says and reset the adapter to factory defaults after each f/w upgrade?
Edward_Z_Intel
I believe you can upgrade from -0036 to latest version directly. Only need reset to factory defaults after upgrade to latest.
diablo_692
I successfully updated the RS2BL040 f/w to version 2.130.363-1846 with package version 12.12.0-124 using RWC2. I appreciate all of your help Edward.
Now for installation of the AXXRPFKDE Premium Feature Key.
