Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
Unknown SAS Controller in Win 2008 for S2600GZ
I have a new Intel R2312GZ4GCSAS server system with the optional RES2SV240 RAID expander card installed.This system comes with the RMS25CB080 hardware RAID module pre-installed.
When installing Windows 2008 R2 with SP1, after installing all chipset, NIC, RAID, and related drivers, I am still seeing an unknown device in Windows Device Manager. It is listed as "SAS Controller" See screenshot here http://screencast.com/t/GnyUbkCmu5 http://screencast.com/t/GnyUbkCmu5
Anyone know which driver I need to install for this?
Jason
Edward_Z_Intel
It could be the onboard SW RAID. Based on your BIOS settings, you could try one the following drivers:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21752&lang=eng Intel® RSTe AHCI & SCU Software RAID driver for Windows*https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20963&lang=eng C600 chipset ESRT2 RAID driver for Windows*
Edward_Z_Intel
SKim70
Daniel_O_Intel
You can also check in the BIOS and disable any onboard controllers not in use. That will usually get rid of the extra controller listed in Device Manager.
