Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4482 Discussions
Upgrading FW for AXX6DRV3GEXP 6-bay w/o an Intel Server Chassis
I have several of these that need a FW update to bypass an issue. How can I do this w/o an Intel chassis?
KAMALANATH_N_Intel
At worst case, select the "other Chassis type" while updating the FRUSDR .
Still i would recommend you to check the compatibility and supported chassis.
http://ark.intel.com/ http://ark.intel.com/
Which board are you using?
Long time ago, i made a /docs/DOC-3013 document on how to update the firmware. Refer to it and let us know if you have any questions.
All the best,
Kind Regards,
Aryan.
Hi Guys,
Thanks very much for the quick responses! I was using an HP and whitebox mobo (two systems with these cages in them) but I just realized I have an Intel SE7525RP2 inside an SC5275E chassis on the bench that does have the HSBP connector on the mobo. I assume the firmware only be upgraded through this port. While the chassis doesn't physically fit the cage, I can access the port from this motherboard possibly?
The ark page doesnt return results for the AXX6DRV3GEXP or the SE7525RP2.
I have a dos bootable cdrom with the firmware files copied to it ready to go if it would work with "Other" chassis type?
Thanks again!
Daniel_O_Intel
Given the two big warnings posted at
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18308&lang=eng
regarding *not* using earlier motherboards to do the update, I don't think I'd feel comfortable using an SE7525RP2, which is even older than the 5000 series.
