Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Urgent! Very slow write speed to SSD-s
SAljoshin
We sold 2 brand new servers and both have the same configuration and both have the same issue-very slow writing speed.
Configuration:
Xeon S4110
S2600WFT
RMS3CC040
SSD D3-4510 4 pcs in RAID5 mode.
8x32 GB 2666MHz ECC memory.
SSDs FW updated t the latest available
Board FW updated to latest available.
Speed test screenshot attached, all other test give the same result.
What is the solution of this problem?
Jeremias_A_Intel
Hello Sergei,
Thank you for contacting Intel Technical Support.
I understand that your clients are experiencing slow performance on two systems sold with the same configuration.
In an effort to better assist you, can you please confirm the following:
  • To which firmware version, you updated the SSDs and Server Board?
  • Were both working fine before?
  • Can you please ask the client extract the full RAID log? This can be done by following the below steps:
  1. Either boot to UEFI, or open a command line as Administrator (Windows*) or root (Linux*).
  2. Download the StorCLI Standalone utility and run storcli /call show AliLog logfile=raidlog.txt.
For Intel® RAID Controllers in non-RAID mode (IT, target, JBOD, or raw), use Windows Event Viewer (Windows) or var/log/messages (Linux).
Older discontinued Intel® RAID Controllers may only be compatible with CmdTool2. For those Intel® RAID Controllers, run CmdTool2 –AdpAliLog –aAll –NoLog > saslog.txt.
storcli show all
may be easier to read, but does not have the logs included.
storcli show alilog
has logs included.
Alternatively, for the hardware Intel® RAID Controller cards, if your system is running the Intel® RAID Web Console 2 Utility, you can extract the TTY logs, too:
  • Have also updated the RAID Controller firmware?
If you have any question, please let me know.
Under Contract to Intel Corporation
Jeremias_A_Intel
Have tested the disks out of the RAID environment?
SAljoshin
We did some tests and seems that problem is related to this raid controller or it's firmware:
Intel SSDs S4510: RAID0 - speeds are OK, RAID5-very slow.
Samsung 860 Pro: RAID0 - OK, RAID5-slow.
We changed RAID controller to RS2BL040 and every configuration worked fine:
RAID0 and RAID5 speeds are ok with intel and Samsung SSDs
Sergei
SAljoshin
TTY Logs attached now
Jeremias_A_Intel
Hello Sergei,
Thank you for your update.
Happy to know that you were able to point out the issue. Do you know what is current firmware version of this RAID controller?
Looking forward to your comments.
Jeremiah A.
SAljoshin
Hello Jeremiah,
We are running latest available FW for RMS3cc040 ver. 24.21.0-0091
We also tried to downgrate one and two versions back of FW, but it didn't solve the issue.
Our next step is to try ordinary PCIe RS3 series controller.
As RS2 series controller works well, RS3 should also work fine, at least we hope.
Sergei
Jeremias_A_Intel
Hi Sergei,
I will be looking forward to your new outcomes.
If you have any question please let me know.
Jeremiah A.
Jeremias_A_Intel
Hello Sergei,
I hope you are doing well today.
I was wondering if you were able to do the tests with the PCIe RS3?
Jeremiah A.
SAljoshin
We ordered a new RS3 card, it will take time while it arrives. Seems like, we will be able to test next week only.
Will inform about results.
Sergei
Franklin_S_Intel
Hello Sergei,
We will be waiting for an update from you on the tests. Thank you very much.
Franklin S.
SAljoshin
we got rs3 raid card today and had a possibility to test all combinations. As a result; same problem with rs3 card, very slow write speeds. we just change raid card to rs2 -all works perfect, but when changing it to rs3 or rms3 writing soeed if slow again.
sergei
SAljoshin
also we tested rs3dc040 controller with another platform and there was also very slow writing. Problem seems to be related to controller.
Franklin_S_Intel
Hello Sergei,
Could you please extract some logs from that controller and send them over for further analysis?
Franklin S.
SAljoshin
here you go. please take a look at screensoits attached. one is rs2 and 2 pics of rs3. you see the difference. both are tested in the same platform.
SAljoshin
posted a file.
SAljoshin
posted a file.
SAljoshin
posted a file.
Franklin_S_Intel
Hello Sergei,
We are checking on the pictures and the log file you sent and we will follow up with you as soon as possible.
Franklin S.
SAljoshin
hello,
after many tests we were able to solve this issue.
if we use ssd and uefi installation, the following raid card configuration should be done. strip size 256 kb and read policy have to change to read ahead. take a look at screenshot attached.
sergei.
Franklin_S_Intel
Hello Sergei,
That is great news. Thank you for sharing your findings. Let us know if you encounter any more issues.
Franklin S.
