Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4617 Discussions
VCA 1283LVV one of the nodes in link_down status
FMoon1
Hi unfortunately i didn't find information about VCA and troubleshooting for that type of devices.
I'll try to explain what issues we have.
Our company have remote server with two this card, not so long time ago one of the nodes changed status to link_down.
I tried update BIOS and even update EPROM for this card but it didn't help.
in log vcactld.log find nothing even in debug mode.
Also i've been tried update to latest version, OS Centos 7.3 with latest VCA software and images, but it didn't help too.
Could you answer how we can boot/reset/update for turn on this node.
Thnx.
Hello fysh,
Regarding your inquiry with problem on VCA 1283LVV one of the nodes in link_down status.
Please check the PDF with information on the device: https://www.intel.com/content/dam/support/us/en/documents/server-products/server-accessories/VCA_SoftwareUserGuide.pdf https://www.intel.com/content/dam/support/us/en/documents/server-products/server-accessories/VCA_SoftwareUserGuide.pdf
Also, this version will only work on CentOS 7.2 only.
Could you please provide us with some additional information, for example:
  • Motherboard been use.
  • Memory
Also, will recommend to try to reseat the module.
Please try the following command:
  • Sudo vcactl reset
https://downloadcenter.intel.com/product/87380/Intel-Visual-Compute-Accelerator https://downloadcenter.intel.com/product/87380/Intel-Visual-Compute-Accelerator
On page 16 section 5.3.1 for commands.
If there is anything else we can help please feel free to ask.
Henry A.
FMoon1
Hi thnx for your answer.
Additional information:
Server Based
CPU: Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
MB: Intel S2600WTTR (Version G92187-371)
Memory DDR4 24gb. (sorry i can't detect brand).
# Software.
Linux setrixvca 3.10.0-327.el7.centos.1.3.9.VCA.x86_64 # 1 SMP Thu Aug 4 06:40:11 CEST 2016 x86_64 x86_64 x86_64 GNU/Linux
LSB Version: :core-4.1-amd64:core-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.3.1611 (Core)
Release: 7.3.1611
Codename: Core
"Also, this version will only work on CentOS 7.2 only." - seems not only, cuz other Nodes work fine.
"Also, will recommend to try to reseat the module." - Do you mean pull out board from pci slot?
Also about "Sudo vcactl reset", yeah i did it a lot of times. I tried update EPROM, BIOS, reset and do wait-BIOS.
nothing helps
Hello fysh,
Thank you for all the information.
I understand you have CentOS 7.3 and working on other nodes but for the troubleshooting purposes we will need 7.2.
Please run the vca_elog.py -d nvram_log15.bin
vca_elog.py -a -i nvram_log15-2.bin
and attach the log.
Also, you can contact your local distributor to request for a RMA.
Henry A.
FMoon1
Hi Henry, thnx for your answer.
I tried to search any nvram_log*.bin but no luck, seems this logs disabled in our servers.
Also i tried to find logs in our second one server, same situation, logs not found.
Maybe you can help me, how we can enable this logs in future?.
P.S. Thnx we will try contact with local distributor.
Hello fysh,
Let run a LAB to get the information to recreate the logs.
I will get back to you as soon as possible.
Henry A.
Hello fysh,
I will like to ask you had time to return the CentOS back to 7.2 or if you had time to request the reseller for a replacement card.
Henry A.
Hello fysh,
Thank you for your time and patience.
I will like to ask you first I will like to apologize on the delay.
Also, if you were able to test it with the CentOS 7.2 or contact your local Reseller for a possible RMA.
Henry A.
Hello fysh,
I am sorry but because se haven't heard from you with additional information, I am going to proceed to close this forum. If you have any additional questions please feel free to contact us again.
Henry A.
