Need an IT mode driver that supports this board for Windows 8.1 x32 and x64. The LSI driver claims support for it, but sees troubling behavior, and LSI says that Intel's OEM driver should be used.
Please let us know the model number for the Intel board you have.
I've been told C600 is the base motherboard, with the following add-in card:
PCI\VEN_1000&DEV_0087&SUBSYS_35188086&REV_05 HBA LSI_SAS2 Intel(R) Integrated RAID Module RMS25KB080
The card itself seems to be a RAID card that was actually re-flashed to IT mode firmware. I suspect that the newer LSI driver may be incompatible with the old firmware (and we have no good way to update the firmware in place.)
This is the driver/firmware that they used on the units:
Firmware: 13.00.66.00, Driver: 16.00.00.00-fbsd
I need a windows-compatible version so that I can assist them in their decommissioning.
We noticed that you have an open ticket with our support group 719239. We will proceed to close this thread. Thank you for your understanding.
