Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Virtual Driver Slow Down Windows Boot (RTW3B080)
Wonder if someone could shine some light on this issue.
I have a Raid Controller RTW3B080 with fFast Path IO and a Expansion card RES2SV240 with 4 virtual driver
1- 4x SSD's in Raid 0 where the OS resides.
2- 9x 3TB in Raid 6.
3- 2x 3TB in Raid 1
4- 1x SSD CasheCade
Here is the problem: The VD in Raid 6 i causing the Windows 7 take several minutes to boot, I know this because I can tell by looking the enclosure LED
lights blinking very slowly, if I reformat the VD Windows will boot in about 15 seconds but eventually after a while it will happen again and Windows will take several minutes to load.
I have update the firmware/drivers - (5.2.116.64) not sure about the Expansion Card but once windows load everything works perfectly.
I don't know if was I good explanation but maybe someone here understood and could help me solve this issue.
thanks
Rick
EPakh
We had a similar problem, both with RAID6 and RAID5 with RS2MB044 controller, RES2SV240 expander, and 16 WD Red (uncertified) hard drives. The setup works for a week or two, then slows down to a halt.
