What options might I have to upgrade my workstation? Current configuration is Intel motherboard SC5520 with dual Xeon quad-cores, 5520, and 32g ECC RAM. Everything works great just need more processing power. Would like to optimize what I have if economically possible, before moving up to more expensive workstation.
I am glad you asked. You could still upgrade the processor in your system. You could use the following list as a reference.
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006567.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000006567.html
Keep in mind that for processors in the 5600 family you need to have a minimum board revision to support it. If possible please provide us with the PBA of your board.
Thank you for responding. Platform ID: SC5520SC Bios: S5520.B6B.01.00.0064.05052014142B
Hello GPa ,
Is it possible for you to provide us with the PBA of your board?
Caesar B.
Were you able to get the PBA of your board? This is to provide a better response since the processor support is revision dependent.
David A
Topic Options
