Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4661 Discussions
What is the proper method to replace a hard drive in a raid?
DHeth
Hi all,
This might sound like a basic question but it's something that has plagued me for many years. Is there a documented "method" to replacing a hard drive in a raid? I have an Intel SRCS28X on an Intel S5000PSL board connected to 6 seagate 400GB SATA hard drives, configured in RAID 50.
The drives are getting old and I want to start replacing them one by one. Are there documented steps to do this? Do I have to fail the drive first take it off line then replace the drive with the new unit? I'm looking for the By the Book answer if anyone has it.
I would also like to know the answer to this question. If your hard drives are still working properly and they are in a RAID config why not wait till one dies? When it dies the hotspare will take over. Replace the bad drive with a new one and it should rebuild itself. From the way I was told that is what happens.
Daniel_O_Intel
There is no official sanctioned method to do this.
Unofficially, I'd do exactly what you say. Go into the configuration GUI, mark a drive offline, then replace it and let the RAID rebuild onto the new drive.
However, because I'm paranoid, I would only ever replace a drive with the same manufacturer, model, and firmware. I've seen far too many weird behaviors when having mixed drives in an array.
DHeth
I think that is the method I will have to follow. I was smart enough to purchase replacement drives at the initial point of purchase, so I do happen to have a full 6 disk replacement set.
I just find it interesting that there isn't a more by the book way to do it from Intel.
Thanks Dan_O.
Edward_Z_Intel
I would do a full backup, replace all drives and create a new array, and then restore the data. If you replace hard drives one by one it means you'll need to rebuild your array 6 times, which is quite risky. If a hard drive fails during the rebuild, or even a hard drive has some bad sectors, data loss may occur.
From theory Dan_O's method shoud work although there are the concern's indicated by Edward. Rebuilding an array is risky in and of itself. A valid backup is the best possible way to do this. Plus it would save you a lot of time. Because of the risks involved, Iintel hasn't tested this.
One thing to note, after you replace all your 400GB HDDs with larger HDDs, the array size will still be the same as before. The rebuild will just grab the original "disk" size from the new disks during the rebuild.
You can use the online expansion feature to increase the array size to use all the space of the new HDDs. See the software user's guide for the SRCS28X for information on online expansion.
John
dhetherington,
I checked this in our lab and I made a mistake. My explanation included a feature called Virtual Disk Resizing, where you can increase the size of a virtual disk using unsused space in an array. This feature is not supported on the SRCS28X. Online expansion is to add NEW HDDs to the array to increase the capacity, i.e. adding another same size disk to a RAID 5 array to get additional storage space.
After replacing and rebuilding with larger disks, the virtual drive size will be unchanged as we know. You can, however, use the extra space to create another virtual disk using the "new" unused space.
Sorry for any confusion.
John
