Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
What is the successor for the S5520SC Motherboard?
Jump to solution
HI,
I have an SC5600 chasis and two E5645 processors. I recon that my current S5520SC motherboard supports a certain level of hardware upgrades.
If I only want to replace my motherboard and keep the chassis and the processors, what motherboard should I buy as a more recent version (supports DDR5 for example)?
Thanks!
Tags (2)
Accepted Solutions
Highlighted
Community Manager
Re: What is the successor for the S5520SC Motherboard?
Jump to solution
To answer your question, the processors and chassis are designed to work only with the S5500 Family.
Highlighted
Community Manager
Jump to solution
Jump to solution
Thanks for the answer Dan. So that means that I will have to buy all the components if I plan to upgrade (as the old processors won't work with the new mobo).
Is there a way to link two Intel Servers for 3D rendering purposes efficiently without an active internet connection/router?
Highlighted
Community Manager
Jump to solution
Your affirmation is correct. Regarding your inquiry for "a way to link two Intel Servers for 3D rendering purposes" we regret to inform you that is out of the scope of support for us. Thank you for your understanding.
