Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
What size of A2U44X25NVMEDK bay ?
Where can i get size of A2U44X25NVMEDK bay ?
AlHill
Does this help, or are you looking for more than 2U?
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006238.html A1U44X25NVMEDK and A2U44X25NVMEDK BackPlane Kits for Server Boards...
http://download.intel.com/support/motherboards/server/sb/ta108101.pdf http://download.intel.com/support/motherboards/server/sb/ta108101.pdf
http://ark.intel.com/products/81802/2U-Hot-swap-Drive-Cage-Upgrade-Kit-with-4x-NVMe-SSD-Support-A2U44X25NVMEDK# @specifications 2U Hot-swap Drive Cage Upgrade Kit with 4x NVMe SSD Support A2U44X25NVMEDK Specifications
Doc
I have a non intel server case, and i try to figure out - can i fit this bay into my case.
For example 5.25 bay ?
AlHill
I do not know much about these kits, but I am certain the answer is NO. A 2U product will be 3" high, and is rack mounted.
One of the Intel support staff can confirm this.
Doc
Hello Win32Trojan ,
The server communities are in charge of this product, let me transfer this thread there in order to get one agent to assist you.
Esteban C
The kit is meant to be used with Intel supported chassis, if you want to give it a try with a third party chassis we suggest you check with the chassis manufacturer for compatibility.
You will find a picture on how it looks in our chassis in the following link on page 57:
https://cdn.cnetcontent.com/78/51/78515568-9423-402b-86cf-20d2a988d497.pdf https://cdn.cnetcontent.com/78/51/78515568-9423-402b-86cf-20d2a988d497.pdf
