Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
Where the heck is my Power Supply Signal Connector?!?!?!?
Just bought an S5299-E BRP case with a S5000PSL motherboard. There is no Power Supply Signal Connector cable anywhere.
Is this cable absolutely necessary and can I run my server without it?
Daniel_O_Intel
The BRP is the only one of the three that has that connector - see http://www.intel.com/support/motherboards/server/sb/CS-023218.htm
If yours doesn't, they may have given you either a DP or a WS by mistake.
Yes you are right I got a DP by mistake.
Can I still use this board? The only problem I have no is the fans are running at high speed.
Daniel_O_Intel
I would not recommend using that board with that chassis.
In the event that I have to use this case, is there anyway to turn the fans down and remove the warning light in the front?
Daniel_O_Intel
You can try the tips at http://www.intel.com/support/motherboards/server/sb/CS-022809.htm , but I don't know if they work when using a different chassis than expected
