Server Products
4776 Discussions
Why is Intel Deployment Assistant showing older versions?
ICust49
I just built a new server using an S1200V3RPL board. It has the following versions:
BMC: 1.10.5637
BIOS: 01.04.0002
ME: 03.00.05.068
SDR: 1.06
I booted the Intel Deployment Assistant CD, version 5.2 that shipped with the board. It displays the correct current versions that I have in the BIOS setup.
I select Get System Updates, from www.intel.com (recommended), DHCP and direct connection to Internet (I'm using a wired ethernet connection).
It then shows Update Package: 1.0 30-August 2013, and clicking Show Contents displays:
IBMC Ver: 1.08.5091
SDR Ver: 1.05
BIOS Ver: 01.03.0004
ME Ver: 03.00.04.209
All four appear to be older versions than what I already have installed. Why is the IDA offering me these older versions? There appear to be much newer versions if I check on the web. Should I just forget about using the IDA and update manually instead?
Any advice is appreciated, thanks.
David_A_Intel
I just tried on my end and I got the same results. I am going to report this to our content managers. In the meantime, I would recommend updating the BIOS manually. The most current BIOS version is https://downloadcenter.intel.com/download/24418/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI 02.02.0005; however, you need to install BIOS version https://downloadcenter.intel.com/download/23859/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI 02.01.0002 first.
David_A_Intel
ICust49
I will update manually, but I'd really like to know when the problem is fixed, if practical. Thanks for the prompt reply.
ICust49
Update to 02.01.0002 using the EFI shell completed without a hitch. I actually feel more at home using the shell!
POST completed with no issues and I was able to boot Linux from a CD and all seems good so far.
I will upgrade to 02.02.0005 tomorrow using the shell, already have it ready on a USB.
I think I will do future BIOS upgrades using the shell anyway now that I have become familiar with it.
BD4
Any update on this issue? I'm still seeing it.
