Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5058 Discussions
can't install SBS2011 Standard on S3420GPV because NIC is unknown
I want to install the new Windows SBS2011 on S3420GPV Server. But after the first reboot the install failed because the system can't detect a NIC.
Is there any work around?
Holger
Edward_Z_Intel
there ist now chance to load the driver befor. I can start the sbs2011 in protected mode, install the driver, but then the konfiguration assistand does not start again.
Holger
I found a solution.
WHile the assistand check the network, you can user Shift + F10 to start a DOS-promt. Then enter control and the Controlpanel starts. Add the Nic driver from the CD and go back to the Asisstand.
regards
Webtour
