Extra connector from p4304xxshcn front panel goes where on s1200v3rp board.
It's 2x2 pins in a 3x2 sized connector. The s1200v3rp board has 2 1x2 headers (J1F1 Chassis Intrusion Header and J1G2 HDD LED Header)
next to the larger front panel header J1C3.
Hi!
As I understand, you are trying to connect the front panel connector and has question about it goes integrated. If I infer correctly, I'd recommend referring to
Connector Pin-out (J1E1):
http://download.intel.com/support/motherboards/server/sb/g84364004_s1200v3rp_tps_r2_0.pdf
You could find the Service Guide very useful, as well:
http://www.intel.com/support/motherboards/server/p4304xxs/sb/CS-032410.htm Intel® Server Chassis P4304XXS — Intel® Server Chassis P4000S Family Service Guide
If you would still need further assistance, I'd appreciate if you could, please, provide more insight as to what extra connector that is you refer to.
Hi!
