Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5041 Discussions
hello! S2600STBR LGA3647 SERVER is compatible with only 1 Intel® Xeon® Silver 4110 Processor?
AMEIR
Franklin_S_Intel
Hello Alan,
You can find more about processor population rules here https://www.intel.com/content/dam/support/us/en/documents/server-products/Intel_S2600ST_TPS.pdf on page 40, section 3.4. Basically you can use 1 or 2 processors, but if you are using only one you have to install it on socket CPU_1.
Franklin S.
AMEIR
1-5-1-2 VR Watchdog Timer DC DC VR Controller in unfinished sequence with no time to resolve error?
Franklin_S_Intel
Hello Alan,
Is that happening to the same system that we were talking about in the previous question? Was it working before or is it brand new? Did you make any hardware changes, bios updates, etc to it before the error happened?
Franklin S.
AMEIR
Olá Franklin, sim o mesmo da pergunta anterior, é um sistema novo que estamos montando, mas já conseguir resolver, para funcionar é necessário ligar a fonte aos 2 conectores de fonte 12v mesmo que só coloque 1 processador.
Franklin_S_Intel
Hello Alan,
That is great news! Being that said, should we close this thread or do you have any additional questions or concerns?
Franklin S.
AMEIR
Franklin_S_Intel
Hello Alan,
We will go ahead and close the thread now. Please do not hesitate to contact us back either through our forums or directly if you need anything else.
Franklin S.
