I'm using an Intel Core2 microarchitecture-based Xeon 5440 server, dual socket, totalling 8 cores.
I've read a few docs on "Accounting cycles on Core2 Microarchitecture".
What comes out mostly is for the data bus :
Measuring FSB saturation is straightforward. This can be done in terms of the fraction of bus cycles used for data transfer:
BUS_DRDY_CLOCKS.ALL_AGENTS/CPU_CLK_UNHALTED.BUS
I'm okay with that, but that shows the data bus utilisation.
This one does not take into account the potential snooping from cache coherency, because such operations transit on the address bus. So I won't see if the bus is saturated with snoops from this formula.
My question then is : does anyone know how to compute address bus utilisation ? I must see if this is the bottleneck in my case or not.
Sylvain
- Tags:
- Intel® Xeon®
If you don't get much reply from the Server community, you can also try the Processor community over at http://communities.intel.com/community/tech/processors http://communities.intel.com/community/tech/processors
Hi
I did as you suggested, but it seems that there is not much answer from Processor community either.
Do you know anywhere else I could ask that?
