Server Products
4657 Discussions
ib0: can't use GFP_NOIO for QPs on device hfi1_0, using GFP_KERNEL
NTrud
What does this message mean: ib0: can't use GFP_NOIO for QPs on device hfi1_0, using GFP_KERNEL
How do I fix this?
Thank you for contacting Intel Customer Support.
Based on this lines, I could say it is associated to the way drivers will allocate and manage memory. GFP_NOIO and GFP_KERNEL will change the blocking level and has many usages.
I would like to know what Intel product you have, your system configuration and any other detail you would like to add, so we can better assist you.
faugub_intel # iwork4intel
NTrud
Please let me know if there is more you need than this. If so, please specify what specifically you would like. Thank you.
HW:
-Kennedy Pass Motherboard
-Broadwell Processor
-PCIe-3 Single Port OPA 100 GBE/s
-8 GB DDR4 DIMM
SW:
-BIOS: SE5C610.86B.01.01.0015.012820160943
-RHEL 6.4
Thank you for the information you shared.
This is not a problem associated with hardware parts. The issue remains in the usage and allocation blocking tasks. This is something configurable in different ways and differs on the purpose of your system.
I recommend to contact the Linux community for guidance on this topic.
