Please let me know ipmitool raw command for controlling S2600CP Fans?
Could you show me the examples of ipmitool raw command for controlling fans in S2600CP board?
Thanks in advance,
Is there any specific control you need to have on the fans?
The reason I asked is that the BMC controller should be able to program your system fans to run properly. You can program this upon running the Firmware Update Package for the board.
I'd like to control the speed of the FANs manually, not automatically.
So, I want to know the method to adjust PWM values of the FANs.
If there is a ipmitool command, please let me know it.
In this particular case, I would recommend contacting http://www.intel.com/p/en_US/support/contactsupport Intel® Customer Support to follow up your request.
You might want to consider these changes to be performed through the http://download.intel.com/support/motherboards/server/sb/updating_frusdr_on_epsd_server.pdf FRUSDR update.
Hi.
I also need to manually change PWM of the fans on S2600CP.
Did you have any success controlling that?
Itay
