I am running windows 10 & tried to upgrade my bios firmware of intel s1200rp using my IDA disc, which came with the system purchase.
but after following upgrade instructions of online upgrade it says already latest firmware installed.
fact is intel website shows too many updates came after the one which was on my board, & latest one was winPE installation, which i dont know how to perform, i have already download the file from intel site.
https://downloadcenter.intel.com/download/26333/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-Intel-One-Boot-Flash-Update-Intel-OFU-WinPE-?product=77870 Download Intel® Server Board S1200V3RPL/S1200V3RPO/S1200V3RPM Firmware Update Package for Intel® One Boot Flash Update (…
Can you tell me exactly steps how to upgrade bios firmware? please.
I understand that sometimes updating the firmware may be confusing. The best way to do this is is through the EFI shell.
In this case download the firmware package in the following link:
If your board is an S1200V3RPS use the following link:
https://downloadcenter.intel.com/download/26537/Intel-Server-Board-S1200V3RPS-Firmware-Update-Package-for-EFI?product=77870 https://downloadcenter.intel.com/download/26537/Intel-Server-Board-S1200V3RPS-Firmware-Update-Package-for-EFI?product=77870
If you server board is either S1200V3RPL/S1200V3RPO/S1200V3RPM
use this link below:
https://downloadcenter.intel.com/download/26301/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI?product=71384 https://downloadcenter.intel.com/download/26301/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI?product=71384
The instructions are as follows:
-Once you extract the package copy all the contents of the folder into the root of a flash drive formatted as FAT32.
-Reboot the system and press F6 to go to the boot options.
-Choose internal EFI shell and press enter.
-The system will boot to EFI and read tha package automatically if the contents are in the root
-Just press any key to continue when it asks for it.
-Let it run all the packages (BIOS, BMC, ME and FRUSDR).
Let us know if you need further assistance.
Thank you for your guidance.
i am glad that intel customer support is quick and correct for Asked question.
thanks again guys
