Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
4329 Discussions
is compatible OFU with windows 2003 server, standar edition?
Community Manager
thanks
Marcelo
Daniel_O_Intel
Since it wasn't tested, it may not work reliably. I would recommend staying with one of the OSes listed in the PDF at http://www.intel.com/support/motherboards/server/sysmgmt/sb/CS-029303.htm http://www.intel.com/support/motherboards/server/sysmgmt/sb/CS-029303.htm
