Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4552 Discussions
m10jnp2sb Server board with a Xeon E-2278G
Vince2766
I have a Intel m10jnp2sb Server board with a Xeon E-2278G / 3.4 GHz processor.
I have an ATX Case -  Fractal Design Node 804 No Power Supply MicroATX Cube Case FD-CA-NODE-804-BL, Black
with a Power Supply - Seasonic FOCUS PX-850, 850W 80+ Platinum Full-Modular, Fan Control in Fanless, Silent, and Cooling M...
I have 64GB of the required DIMM outline for this board.
https://www.intel.com/content/www/us/en/support/articles/000055644/server-products/server-boards.html - This link shows I need the        Sea Sonic FOCUS PLUS* 1000 Gold SSR-1000FX 1000W
I have everything connected properly.   The problem I am seeing is the server turns on, but it makes a few clicking sounds without drives hooked up, and flashes / blinks constant Green Lights on the board and one of the PCI-e 3.0 x8 card I have in one of the PCI slots.
Can someone please assist me if this is a Power Supply problem, bad CPU or a bad motherboard?
JoseH_Intel
Hello Vince2766,
Thank you for joining the Intel community
It is soon to tell about a possible PSU incompatibility. I would suggest to reseat all the cabling and try a minimal configuration (board, CPU, 1 DIMM) to check the behavior. Based on the outcome we can move on.
I will look forward for your updates.
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
JoseH_Intel
Hello Vince2766,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you on next Tuesday 6th. After that the thread will be automatically archived.
Jose A.
JoseH_Intel
Hello Vince2766,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
