We are experiencing the following warnings/errors and are wondering how we can prevent them.
From Vmware 6.5 directly on Host:
Health of other changed from green to red . Sensor name: Memory Module 2 DIMM Thrm Mrgn 2 --- 0.8.2.177
Health of other changed from red to green. Sensor name: Memory Module 4 DIMM Thrm Mrgn 4 --- 0.8.4.179
Hardware:
Intel 2600TPR within R2308WT2GSR Chassis
Intel Xeon E5-2630V4
MEM : 32G
IPMI:
DIMM Thrm Mrgn 1 Normal OK -51 degrees C
DIMM Thrm Mrgn 2 Normal Unknown Not Available
And the host turns off automatically.
From IPMI we see Sensor 2 and 4 not being available ....is this normal?
Can anyone clarify if this is normal behaviour?
Hello 김민기00,
Thank you for joining the community
Could you tell when did this issue started? Have you added any new device recently that might affect the internal airflow of the server?
Could you please attach the memory manufacturer and part number so we can confirm for compatibility?
We will look forward for your updates
Jose A.
Under Contract to Intel Corporation
Hello 김민기00,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this.
If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved.
This thread will be marked as resolved automatically in the next 72 hours if no activity is received.
Jose A.
Hello 김민기00,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
