Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4548 Discussions
motherboards header pins intel d865gvhz
hey there please help me. I was trying to instal a hardware and instead took all the header pins out of the motherboard and now i dont know where are the proper plug ins to put them back. please help me by giving me instructions if possible, THANK YOU, SORRY FOR BAD SPELLING
d865gvhz
these are the lil cables that need to be pluged in properly
i have MIC BIAS,GND,GND,R IN, R OUT,L IN, L OUT, MIC IN
POWER SW,RESET SW,POWER LED +,POWER LED -,
GND2,DATA -2,DATA 2, VCC 2 GND1,DATA-1, DATA1, VCC1
no1 can help me
JLodh
New Contributor II
Hi Guest,
Follow the URL below and you will find details to all connectors on your motherboard including the front panel connectors, and front panel USB connectors.
In case you encounter any problems, feel free to contact us.
http://www.intel.com/design/motherbd/hz/hz_con.htm D865GVHZ Connectors Configuration
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
