hi all, sorry my english!
my server:
Manufacturer Intel
Model S5500HCV
AA Number E40912-455
BIOS Vendor Intel Corp.
BIOS Version Intel Corp. S5500.86B.01.00.0059.082320111421
BIOS Release Date 09/30/09
Operating System (O/S) Microsoft Windows Server 2003 R2, Standard Edition Service Pack 2
Operating System Build (O/S) (build 3790)
Operating System (version) 5.2.3790
1. If system shutdown - server shut down -> wake on lan don't work!!! if send broadcast on server lan mac adress magic package - server power off
2. if system reset - server shutdown -> wake on lan don't work!!! if send broadcast on server lan mac adress magic package - server power off
3. if press power button 4-5 sec, server shutdown - > wake on lan worked!!! if send broadcast on server lan mac adress magic package - server power on
in system i config shedule with power on for this shedule 5 min repeat, <- don't work
i can reset server remote, if i reset server, server shutdown , and wake on lan, after this shutdown, don't work
why?
can i setup bios for permanent(persistent) power on? if i (or else) shut down server - BIOS power on server after 1-2 min
help me please!
You may need to configure the NICs in OS to enable WOL... See if this helps: http://www.intel.com/support/motherboards/server/sb/CS-032238.htm http://www.intel.com/support/motherboards/server/sb/CS-032238.htm
my server cant software reset.
my server only shutdown...
if system(software) send reset or shutdown commant - server shutdown! after this shutdown WOL not works.
if press hardware power button(4-5sec) server shutdown too, but after this shutdown WOL works perfect!
Do you have the latest http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18180&ProdId=3069&lang=eng chipset driver, http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18388&ProdId=3069&lang=eng LAN driver and http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18387&ProdId=3069&lang=eng video driver installed?
