Server Products
4956 Discussions
need help with Manufacturer: Intel Product Name: SE7501WV2S, BMC errors
Hi all,
we are having some crashed on this motherboard. and the error is:
ipmitool -I imb sel list
4 | 11/16/2012 | 05:03:39 | Event Logging Disabled # 0x09 | Log area reset/cleared | Asserted
18 | 11/16/2012 | 05:15:36 | Unknown # 0x85 | State Asserted
2c | 11/16/2012 | 05:15:37 | Critical Interrupt # 0x07 | Bus Uncorrectable error | Asserted
40 | 11/16/2012 | 05:22:40 | System Event # 0x83 | Timestamp Clock Sync | Asserted
54 | 11/16/2012 | 05:22:40 | System Event # 0x83 | Timestamp Clock Sync | Asserted
68 | 11/16/2012 | 05:23:32 | System Event # 0x83 | OEM System boot event | Asserted
7c | 11/16/2012 | 10:56:29 | System Event # 0x83 | Timestamp Clock Sync | Asserted
90 | 11/16/2012 | 10:56:29 | System Event # 0x83 | Timestamp Clock Sync | Asserted
a4 | 11/16/2012 | 10:56:51 | System Event # 0x83 | OEM System boot event | Asserted
b8 | 11/16/2012 | 12:23:33 | Unknown # 0x85 | State Asserted
cc | 11/16/2012 | 12:23:33 | Critical Interrupt # 0x07 | Bus Uncorrectable error | Asserted
e0 | 11/16/2012 | 12:42:07 | System Event # 0x83 | Timestamp Clock Sync | Asserted
f4 | 11/16/2012 | 12:42:07 | System Event # 0x83 | Timestamp Clock Sync | Asserted
108 | 11/16/2012 | 12:42:57 | System Event # 0x83 | OEM System boot event | Asserted
also the BMC shows the event log is enabled, but when trying to get again the sel i got:
[root@ugs1a root]# ipmitool -I imb mc getenables
Receive Message Queue Interrupt : enabled
Event Message Buffer Full Interrupt : enabled
Event Message Buffer : enabled
System Event Logging : enabled
OEM 0 : disabled
OEM 1 : disabled
OEM 2 : disabled
[root@ugs1a root]#
[root@ugs1a root]# ipmitool -I imb sel list
4 | 11/23/2012 | 05:03:08 | Event Logging Disabled # 0x09 | Log area reset/cleared | Asserted
[root@ugs1a root]#
please can anyone help me out
regards,
Shpetim Aliaj
DSilv11
Valued Contributor III
I will start with, I suck at linux.....
The SELVIEW tool (which i can't seem to locate for this board.It should be on the resource CD). will give you a much better picture of what is occuring.
IPMITOOL does not report all the values that get logged which leaves you guesing.
So here is my guess,
18 | 11/16/2012 | 05:15:36 | Unknown # 0x85 | State Asserted --- Something stopped responding. could be ablut anything. Hence UNKNOWN,
2c | 11/16/2012 | 05:15:37 | Critical Interrupt # 0x07 | Bus Uncorrectable error | Asserted - System attempted to recover and can't. Blue screen (execpt that your in Linux)
I would try removing any add in cards and run far a bit to see if the error goes away.
If so, add the cards back until you start getting the error again.
Hi Doc_SilverCreek,
Thanks a lot for your help. i managed to install the ipmiutil and now one of the errors seem more readable:
0018 11/26/12 08:05:49 CRT BMC SMI Timeout # 85 SMI asserted 03 [41 0f ff]
002c 11/26/12 08:05:49 CRT BMC Critical Interrupt # 07 Bus Error 6f [88 08 ff]
i will try to google for the new CRT BMC SMI Timeout # 85 SMI asserted 03 [41 0f ff]. as SELVIEW or the resource CD are not available for download.
regards,
Shpetim Aliaj
