Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5079 Discussions
need some help - I would like to know how we can get the NVMe info using redfish
sm25
I would like to know if there is any way that we can query NVMe info using Redfish or IPMI, we are getting some issues like if a disk failed on our host that is creating some mess and we are not getting NVMe info from BMC, so I would like to know if there any way that we can query .
Base board details: S2600WFT and M50CYP2SBSTD
Thanks in advance.
Fikri_Intel
Hi sm25,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. Based on your queries, you can find the information on the Technical Product Specification as below:
https://www.intel.com/content/www/us/en/support/articles/000058779/server-products/single-node-servers.html
https://www.intel.com/content/www/us/en/support/articles/000023750/server-products/server-boards.html
Fikri O.
sm25
Hi Fikri,
Thanks for your response,
Unfortunately I can't find anything in those articles related to querying the data using either IPMI or Redfish.
sm
Poojitha
Hi sm25,
Greetings for the day!
Apologies for the inconvenience caused. We kindly request you to refer to the link below for complete NVMe information. In the meantime, we kindly ask for some time to check the details and provide you with an update.
https://www.intel.com/content/dam/support/us/en/documents/server-products/intel-server-obmc-redfish-interface.pdf
We appreciate your understanding!
Poojitha N
Fikri_Intel
Hi sm25,
Good day to you.
Just wanted to follow up with you, kindly let us know if you have further concerns.
Fikri O.
Fikri_Intel
Hi sm25,
Hope you are doing well.
Since we have not seen an update, we will be closing this forum case from our end.
Fikri O.
