Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4482 Discussions
problem in dp45 sg
Dear Expert
i have dp45 sg +cpu q8200+ ram gil , when i turn off after 4 or 5 item , my system not turn on or not boot , i changed my ram - power supply & vga , but it was the same situation, i checked number code cpu it was in list of compatible , i changed my mb & cpu the same model- AA & bios version , but was the same before ,. after test with 4 pcs mainboard , one of the them was good & didnt have any problem , i asked another person , we had have the same problem .of course for next test i used of ddr3 4G (2*2)1333 kingston (KVR1333D3N9/2G)- POWER 585 real , pls tell me what can i do for run motherboards dp 45 sg
Manouchehr.Aghazadeh
Daniel_O_Intel
You might try over in the desktop community - http://communities.intel.com/community/tech/desktop
