Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4299 Discussions
problem with my notebook battery and the sound hardware...help me plssss...
Community Manager
the power meter of my laptop when charging shows "0% charging", does it mean i should buy
a new one or maybe something should i adjust?
and also, do you know why does the "sounds and audio devices" of my laptop will automatically
updating and if it will update, my sound and audio device gets lost and will not function anymore...
but when i roll back the hardware "conexant high definition hardware", it will make sound again...
what should i do to make the device specifically the hardware "conexant high definition hardware" will update properly and
will not interupt my sound hardware? can you help me plssss with my problem? thanks!
William_L_Intel1
Thanks for your question. If your battery won't hold a charge, likely you will need to replace it. As for the audio problems, it may be an issue with the software driver having some kind of conflict. If you have more than one audio driver you may want to delete and then re-install the coxnexant driver. Let us know if this helps solve your issue.
