what does it mean?
my mainboard is w2600cr .
Hello Sr,
Could you detail a bit more where did you get this error from? Is it showing during boot? If this is the case then you need to follow this article https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007049.html https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007049.html
If this is not the case please provide more info and we will be glad to assist you.
Jose H.
You could try disabling the PXE boot NIC option under BIOS.
Jose H.
it is during boot BIOS POST phase , doesn't look like soft boot agent thing .
In that case could you please provide the current BIOS version installed, memory and CPU configurations, PCI devices attached and any other information you consider relevant.
If you could perform a BIOS default procedure (F9) please do and let us know the outcome.
Will be waiting for your updates.
Jose H.
this might be the thing you mentioned , i am trying your advices .
and i use 2 or 3 GPUs always , besides a quadro P2000 , there is a quadro K620 ; and before my K5200 went wrong , i used quadro K5200+K620+K80 combination , running adobe premiere pro cs6 with 6 monitors .
Well, this info you provided is certainly useful but was not exactly what I was referring to.
What I suggest is to disable the PXE boot network device under BIOS > Advanced Boot Options > Legacy Network Device Order, try disabling whatever you find there.
Let me know how it goes.
Jose H.
well i have looked through my BIOS setup menu , there is no "boot maintenance" sort of entry , and those options look for group coworking machines , and mine is single isolated platform .
so far my machine can just live with that bug and run normally , i just leave it there .
thank you very much for your help in any way .
I will continue researching on this and will update you if I find something.
Thanks for contacting us.
Jose H.
