Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
"syscfg /hc https 3 enable 443" -> Invalid data in the switch parameters
PLe3
A Services guy did disable the HTTPS access by error from the RMM4 GUI and we can't recover the previous state and we don't have anymore access to the RMM4 Web features. The customer lab is available only remotely so we are blocked to change any parameters from the BIOS menu
Via SSH, I tried this Sysconfig command but the tool reports bad arguments while I follow the command line requested into the RMM4 Intel User guide.
Some information about this module:
"syscfg /d lan 3"
LAN Configuration Settings:
LAN Channel Selected: 3
LAN Alert Destination Index Selected: None. LAN Alert Configuration will not be displayed.
IP Address Source: DHCP
DNS Primary Server IP Address: 10.86.88.200
DNS Secondary Server IP Address: 10.86.88.100
DHCP Host Name: BMCA4BF013E6701
LAN Failover Mode: DISABLE(NIC1:DISABLE,NIC2:DISABLE,NIC3:DISABLE,PrimaryNIC:1)
BMC Host IP Address: 10.86.74.144
Subnet Mask: 255.255.248.0
Gateway IP Address: 10.86.72.1
Gateway MAC Address: 00-00-00-00-00-00
Backup Gateway IP Address: 0.0.0.0
Backup Gateway MAC Address: 00-00-00-00-00-00
Community String: public
Gratuitous ARP Enable: DISABLE
Gratuitous ARP Interval (milliseconds): 4
BMC ARP Response Enable: ENABLE
"syscfg /d user 2 3"
User ID Selected: 2
Channel Selected: 3
User Name: root
User Status: ENABLE
Privilege Level Limit: ADMIN
SOL Enable: DISABLE
Any help would be appreciated.
PLe3
Hello Jose,
Here is the response from our customer:
Thanks for this update. I did try first to use the command remotely with the “-I lanplus” parameter but it failed all the time with this error:
Error in open session response message : insufficient resources for session
Error: Unable to establish IPMI v2 / RMCP+ session
None of the hundred google tips to try to fix this error did work. If Intel has any clues on this I would be happy to know it….
However using an SSH session on one of the other IP port of an affected system works. So the workaround so far is the following:
  • Log to the server with SSH on the IP server network address
  • Once logged, enter the following command: “ipmitool raw 0x30 0xb1 0x01 0x79 0x00”
  • Reboot the system
  • You will be able to log again on the RMM Web GUI page
Please report to Intel in case they have a way to fix remote IPMI issues as stated above.
JoseH_Intel
Hello PLe3,
Thank you for joining the community
For our records could you please tell what board model do you have?
About the syscfg arguments we will need to do further research. In the meantime you can check the SYSCFG user guide
We will look forward for your updates
Jose A.
A Contingent Worker at Intel
PLe3
Hello Jose_Intel,
Thank you for your reply. I checked the user guide. The command syscfg /hc https 3 enable 443 is correct.
I am gathering more info on the motherboard model. Will update shortly.
Thank you
PLe3
Here is the motherboard info:
It’s an S2600WFT with BIOS 2.01.008 installed.
Manufacturing Time(mins)         : Tue Aug 29 11:05:00 2017
Manufacturing Name(ASCII)      : Intel Corporation
Product Name(ASCII)                   : S2600WFT
Serial Number(ASCII)                    : BQWF73400369
Part Number(ASCII)                       : H48104-850
Mftr FRU File ID(ASCII)                : FRU Ver 1.00
Sysinfo of the system is also attached
JoseH_Intel
Hello PLe3,
Thanks for the updates. I will research about the syscfg commands and will let you know as soon as possible.
Jose A.
JoseH_Intel
Hello PLe3,
Could you please try to run the following raw IPMI command: "raw 0x30 0xb1 0x01 0x79 0x00"
The example command would be similar to "ipmitool -I lanplus -H <IP address> -U <user> -P <password> raw 0x30 0xb1 0x01 0x79 0x00" to enable the HTTPS services for BMC web console. Here the <IP address>, <user> and <password> are for the BMC of remote system. Refer to the specific open ipmitool for the exact command format.
Jose A.
PLe3
Hello Jose,
Thank you. I will let you know if it works or not.
JoseH_Intel
Hello PLe3,
We will wait for your updates.
Jose A.
PLe3
Hello Jose,
  • Reboot the system
JoseH_Intel
Hello PLe3,
Thanks for the feedback. We will definitely report it to engineering in order for this issue to be noted. For now we will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
