Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4543 Discussions
r1000rpo cannot install chipset driver
PFunk
Trying to install chipset driver on Hyper-v Server 2012 r2, error says system does not meet minimum requirements, 16GB of Ram, and a 3.3Ghz E3 processor. The last time I did one it worked fine from command line installing the Null driver. All components were selected using the Server Configuration tool.
David_A_Intel
Not sure why you are getting this message. Let's try this driver version instead https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility- 10.0.24
