Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
raid Configuration on intel s2600cp motherboard
sBhan31
Hi All,
i have first time configured to raid , On board RAID on interls2600cp mother.
I have done the following steps
1) i have set raid mode in BIOS > Advance > Mass storage controller Configuration
ACHI Capable SATA Controller [RAID Mode]
and restart the system and trying to configure RAID using Ctrl + E , Ctrl + A, Ctrl + S
But not showing RAID Utility.
Please guide me for on board raid configuration in s2600cp mother board OR how to configure RAID option in Intel motherboard
Sandeep
RNeuh
Hey Sandeep,
you may wanna try the Intel Deployment Assistant, simply download the following ISO https://downloadcenter.intel.com/downloads/eula/21848/Intel-Deployment-Assistant-iso-image-file?httpDown=https://downloadmirror.intel.com/21848/eng/IDA%20v5.0-Build%2019.iso Intel® Deployment Assistant iso image file and burn it to a CD, then boot from the CD and run through the setup after accepting the licencing agreement, simply look for the option "Raid Setup" or "Raid Configuration".
Let me know if that worked for you!
Greetings,
newb.
