I moved the server 6 inches and now it wont start. Just one long beep and nothing else. no display either.
the diagnostic leds show 0 0 0 X 0 X 0 X
the manual does not cover the led combo above. any thoughts?
Tried unplugging and re-plugging the power cord, removing all power and
connections from M/B, reseating all components, same 1 long beep and nothing else.
Please help
Here are our recommendations:
- Clear the CMOS battery by removing it for one minute and power cycle the board.
- Take the board out of the chassis and test it over a non static surface with minimum components installed (processor, memory). You can use pins 11 and 13 to power up the board.
- Test the system without memory installed looking for beep codes. If you get 3 beep codes, test with different memory.
- If possible test the system with a regular ATX power supply.
- If the issue persists after removing memory and the power supply, we recommend contacting our support group via phone to replace the board under warranty.
just a follow up: this is custom built server running windows 2012 r2 and it has been
running for the past 6 months.
