Dear All,
just aquired a se7501br2 which is 5200 intel tower base with se7501br2 motherboard. I do not have se7501br2 system resource iso and on serching cannot find it to download, any advice please
Chris
- Tags:
- Intel® Xeon®
The complete Resource CD ISO is not available for download. However, if you need the System Set-up Utility (SSU) to configure the system, here is the link:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=8158&ProdId=883&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=8158
Other drivers/utilities on the CD are also available for download seperately.
Thanks for the response, I had previously downloaded all the files, and unpacked them on flopies.
Having done this and then started machine and got to C:\ prompt the system could not run the exe file, would the DOS version be a problem here? the floppy is not bootable, should it be a system boot floppy, in reading the use of CD the CD is bootable. Assistance is greatly appreciated
The floppy diskettes don't need to be bootable. You should run the file "1R1D1DI.EXE" from hard drive, and the bootable image will be written to the floppy.
Please note that this is a 16-bit program and will not run in 64-bit OSes.
