Hi , We have problem server Intel SR2500 the server hang , and there is no post , no video output
We recommend contacting our support group directly for assistance on extracting the server logs and narrow the issue accurately:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Remove the memory modules and try to power-on. If no beeps - that can be PSU or motherboard.
Hi , How i can know if the problem is motherboard or PSU , Because the server work there is SSH connection , but many time hang without Error message OS log , no SSH connection and the server have 2 PSU
So if sever actually works for some time, enable all event logs in BIOS Setup and, after next hang and power cycle, read BIOS event log, it may contain the clues.
Hi, How we can read BIOS event log
Ow, that hardware may not contain event log viewer in BIOS setup. If so, proceed to
http://www.intel.com/support/motherboards/server/sb/CS-031911.htm http://www.intel.com/support/motherboards/server/sb/CS-031911.htm
