Server Products
4761 Discussions
server motherboard S1200SPL
EKai
To answer your question, the situation is not normal. Our recommendation is using validated memory which can be found here:
https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 Server Configurator
Login as a guest, click on "THOL Builder" select "S1200SPL" and use the different filters to locate the validated hardware.
