H2224XXLR2 , with S2600TPR board, with most current firmware package R01.01.0028
The behaviour is identical to the one described in TA-1131 :
"Intel has received numerous reports from customers of unexpected and severe system CPU throttling on the identified products. The event is also coupled with a Power Supply Amber LED warning (1 Hz blink pattern) status generated by the event. A check of the System Event Log (SEL) shows a PSU Predictive Failure, an Over Temperature condition, or a SmART-CLST event."
Is there a more current PSU firmware version? Is this known behaviour? (as it apparantly was before) ?
-Jan
- Tags:
- power
- « Previous
- Next »
Hello JanKuipers,
We are following your issue and we would like to know if you were able to perform the recommendations that we provided you on the previous post.
Sergio S.
- « Previous
- Next »
