Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
snmp agent using ipmi
OSEN
Hi ,
We want to code a program (java) that queries remote snmp servers data that is provided by ipmi interface for that I think intel platforms should proivde
1) snmp oids?
2) a small application that pulls the ipmi that and serves it .
What we want to do is that we want to show server healt status on our own program. Something like Multi-ServerManager-1.0-Build22_Windows. My question is
1) Is there a defined SNMP OID for intel platforms that we can use?
2) Since we use FreeBSD as our platforms operating system we need to interpret ipmi output and serve it. Maybe such a program is written for Linux or Windows but specs are open and we can benefit from that?
Can someone in this list guide me on how to do that since i am a little bit lost on how to do that.
Daniel_O_Intel
Yes, you are in luck! There are MIBs for almost every server - which one do you have?
Intel has also put effort into supporting IPMI in the open-source community - see http://ipmitool.sourceforge.net/ http://ipmitool.sourceforge.net/
OSEN
The server is Intel platform (SR1625urr or SR2612). I have found out that there is snmp support on it. But when I set the community name to "public"
ipmitool lan set 1 snmp public
I can't query it but i can ping the ipmi interface from another machine on the same lan
ipmitool lan print 1
Set in Progress : Set Complete
Auth Type Support : NONE MD5 PASSWORD
Auth Type Enable : Callback : NONE MD5 PASSWORD
: User : NONE MD5 PASSWORD
: Operator : NONE MD5 PASSWORD
: Admin : NONE MD5 PASSWORD
: OEM :
IP Address Source : Static Address
IP Address : 10.0.0.140
Subnet Mask : 255.255.255.0
MAC Address : 90:fb:a6:dd:14:cX
SNMP Community String : public
IP Header : TTL=0x00 Flags=0x00 Precedence=0x00 TOS=0x00
BMC ARP Control : ARP Responses Enabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 0.0 seconds
Default Gateway IP : 10.0.0.1
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
802.1q VLAN ID : Disabled
802.1q VLAN Priority : 0
RMCP+ Cipher Suites : 1,2,3,6,7,8,11,12,0
Cipher Suite Priv Max : XaaaXXaaaXXaaXX
: X=Cipher Suite Unused
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
snmpwalk -v 1 -c public
snmpwalk -v 2c -c public
does not work.
Daniel_O_Intel
You may have to enable it first. Have you booted off the Intel Deployment Assistant CD, and gone into the networking configuration? It's been a while since I've done it, but I remember having to do that first before SNMP would answer.
OSEN
Using IDA I can only set trap sender but not snmp server on ipmi I think. Can someone send the syscfg.efi command for that? There are various commands for snmp but i am not able to figure out which one is to enable SNMP queries on IPMI lan 1 interface (or for RMM3 also)
Regards.
OSEN
there are a few targets/switches related with snmp at syscfg
/lac = lan alert configuration
/lae = lan alert enable
/lc = lan configutration
/sc = serical configuration
/spe = serial page enable
Which one should i use and can you give me an example for example for rmm3
syscfg /lae 3 <_community_name>
this changes community name which i can see using ipmitool
: OEM :
IP Address : 10.0.0.100
MAC Address : 00:1e:67:08:e0:ab
SNMP Community String : public1
but i can't still snmpwalk it
